Is the 115V AC Outlet an Easy Option to Add After Delivery?
zeppelin
I'm already kind of regretting that I did not order my 4R with the 115V AC outlet as an option. Is this an easy option to add to a vehicle that comes without it?
not sure about the Toyota option, but adding a power inverter is relatively simple. Just make sure you have the correct wiring to set these up (generally straight from the battery, fused with a minimum 12 gauge wire)
It would probally be more cost effective to add an aftermarket inverter rather than the factory one. Yes it won't look factory, but the factory inverter is only good to 400 watts. You can do better than that aftermaket, and it will be hella easier to install. I have one under my passenger seat that I use for all sorts of stuff.
pictures by any chance?
workingwheelswnc
