Is there a way to disable the rear window going down.
liquidvw
06 4R SR5 V6
Parked the 4R last week in a lot. When I came back, the rear window was down. I must have pressed the remote when it was in my pocket when I was walking away. Is there anyway to disable this? I don't want this to happen again.
liquidvw said:
06 4R SR5 V6
Not that I know of, just be careful next time! I bet you wouldn't like the roll down window feature on all Lexus vehicles.. If you accidentally open your Lexus and hold down the unlock button, ALL the windows will roll down, and the moonroof will also open. :p
There actually is a way to disable the remote control such that it can't lower the window. You'll need to find a Toyota dealer who understands what Customizable Body Electronics Settings, or C-BEST settings, are. My dealer doesn't get it. :(
The body electronics have a few settings that can be changed. Search the forum for "C-BEST" and you'll find the list.
These are the things where the Owners Manual says something like "this behavior can be changed - see your Toyota dealer for assistance." My dealer told me that the manual was wrong, and nothing can be changed. I know that's not true, since my last car was a Lexus, and Lexus has had C-BEST settings for many years (now called "Lexus Personalized Settings", or LPS). The Toyota vehicles use similar (if not the same) computers, and 4Runner has had some C-BEST settings since 2003.
The way to change C-BEST settings is for the dealer to plug in their OBD scan tool and go through the menus. To get to the Back Window setting, I believe this is the sequence:
"Application Select" Menu: Customize > New Vehicle > plug it in to OBD > Individual Change > Wireless D Lock > B Window Open
Choices for "B(ack) Window Open" are 1 TIME, 2 TIMES, 0.8 PR, OFF. Default is 0.8 PR, which means to press and hold the button for 0.8 seconds. To turn it off, select OFF.
After making the change, the tool asks "Are you sure?"; press YES to confirm, and it's done.
The dealer will most certainly charge you for the labor to do this.
If you disable all windows (that switch on the driver side door...forgot what's its called), shouldn't that prevent any switch, including the remote from opening the rear window?
Rialm
