Is this ALL I need for my lift order?
DanTosh
I'm about ready to order everything I need to get my 3 inch lift on my 1998 4runner. Ive found that everything is pretty confusing but I THINK i've got everything ready to order. I just need yalls help in case I'm missing anything.
I've decided to go ahead and go with new coils and struts/shocks. Heres everything i've compiled:
OME 881 Front coil set + 10mm lift enhancer kit
Old Man Emu Suspension for Toyota 4Runner Trucks- Wheeler's Off-Road, Inc
OME 891 Rear coil set
Rough Country 9000 front and rear shocks
Rough Country Nitro 9000 Shocks from Wheeler's Off-Road, Inc
Front Differential Drop
Toyota 4Runner Suspension Equipment -Wheeler's Off-Road
Will I NEED an extended brake line as well?
Thanks for the help guys. I'd rather order everything at once instead of having to order two or three times.
Thats all you need. I would suggest longer brake lines if you plan on fully extending the wheels like going off road. When I lifted mine the drums would lock when I would go from park. All you have to do is reset the drums so drive in reverse hit the brakes do this a few times at pace. Also pull your ebrake up and down a few times. Dont hit anything. My drums haven't locked up since. Just to clarify they didn't lock up theyd grip for a second then release once i started moving foward.
Also after the lift check your ball joints and CV boots for leaks. Since your going to change the angle of the stuff the old boots may crack and leak. Thats what happened to me.
Good luck
7ron
