is this brand of led good? Is this headlight housing worth it 1.2k
iseeu1001
I just want a clean crisp white light without blinding other drivers coming along.
Amazon.com: AUXITO H11 H8 H9 LED Headlight Bulbs 12000lm Per Set 6500K Cool White Wireless Headlight LED Bulb, Pack of 2: Automotive
About almost all leds say they match the same beam position but I don't know if that will still blind other drivers. Its suppose to be 12000 LM so 6k each side I am guessing.
I also see this pair of headlight retrofit bi-led so is that good but its 1.2k
10-13 Toyota 4Runner Retrofit Black Headlights
I will have this vehicle for a long time like I did my venza or even longer then my venza. I had my venza 2013 for 4 yrs and had a mustang s550 2015 for 2 yrs with my venza.
I think the candidate for this job is the H9 bulbs (or some other H11 bulbs)
Bit long and technical read but overall a good read.
3rd Gen HID vs LED vs Halogen H11 projector headlights | Tacoma World
I'm using the GE Xenon 120s and loving em
A lot of your decision depends on what you are trying to achieve.
Are you trying to improve your vision at night or are you simply trying to make the vehicle look good?
If you are going for performance, as mentioned above, the H9 mod is the simplest and probably most bang for your buck. A true retrofit of an actual HID or LED projector would be the next step, albeit much more labor intensive and expensive.
If you are going for aesthetics, then your options are almost endless.
Everyone has their own opinions on headlights and what performs the best, so ultimately you will need to decide what is the most important for you when it comes to lighting.
DanielShawSZ
