octanejunkie
Elite Member
All this green and red
Thought I'd let this thread die as it served its purpose, but I have a question that can probably get addressed easily here, as opposed to a new thread...
I don't have a lower fan shroud. Never knew until now...
Is this something that I can add later, after the radiator install? Seems like it, but I'd like to make sure... Thanks.
The factory fan shroud has a little hoop around the bottom that is removable, is that what you are talking about? If so, its there to allow you to remove the radiator and/or shroud without removing the fan itself. So yeah, it can be added back later if it is currently missing.
-Charlie
Lower fan shroud 16702-62030
Get the two metal clips that secure the hoop too 90468-06092, you need 2
Sourced from https://parts.olathetoyota.com/auto...-cat/cooling-fan-scat/?part_number=1636162010
