Is This The Oil Drain Plug?
Ryker
I have seen several threads saying the location of the oil drain plug is under a plastic cover. I couldn't find a plastic cover and the only thing that I think could be the plug is here. Is this it?
Looks like it.
Kinda hard to tell due to the size of the pic, though. The drain plug is behind the skid plate, but there is a hole in the plate allowing access to it.
Take the tools and oil back to the store. You don't want to mess this up.
Seriously though, if you don't know, get someone in your area on the forum to help you with the oil change. It is easy to do but it is also easy to blow an engine if you mess something up.
There has to be another forum brother in your area that will help you. Hint hint hint :wave::help:
bobdjr41
