ok, the cabin interior neons are from Redline, their Ultrabrite 9 inch thin tubes. They have a transformer that after 2 minutes they glow maximum brightness.
The ones under the dash are pretty simple, find an area under your driver's side however, the underdash under the passenger side was hell of a time. If you go up under it you'll find a plastic panel. You will discover that the 4 wheel drive unit and the tire pressure unit is mounted on that plastic plate. unscrew both of them and unclip the metal brackets that are mounted to the modules. Now you can actually move the two modules into the kick panel on the passenger side! There is plenty of room in the passenger kickpanel for the two modules to sit in there.
now you can mount the passenger side neon
The ones underneath the front two seats are ziptied to the brace of the seat cover. The wiring is ran through the carpet where the under seat vents are, make sure to leave some slack so the seat can move back and forth. and then sneaked to the door sill.
The neon in the rear cargo area is a 15 inch neon tube that probably needs to be replaced with the ultrabrite, and it was ran along the privacy bar/sheet mechanism, and through the pocket on the left driver's wheel well. I used a RC Tamiya connector so in case I need to drop the seats down and remove the that bar, I can disconnect the neon quickly and not worry about it being shorted.
hope that helps!
I work at best buy, that's where those interior lights came from. however each tube is 25 bucks.
www.redline.net is the website.. but their website never works... annoying... they are VERY bright...
