Jba uca
Mybuddytmil
Got the eibach lift kit and ordered jba control arms. I am planning to use factory trail wheels and factory size tires possibly wildpeaks. Am I gonna have any issues if I don't use wheel spacers? I really don't want to use spacers.
I also plan to install the Eibach lift so I emailed JBA about tire sizes on stock trail wheels using their UCA.
The owner said 275/70r17 and 255/75r17 would work with JBA UCA and trail wheels so you will be fine with stock tire size. He said for 285/70r17 tires you would need at least a 1/2 in spacer.
Don't need a new thread for this, you can find lots of JBA setups around here by search.
JBA is fast in responding too if you have any questions.
That said, I ran 285 and 275 tires on factory wheels with a spacer. factory sized tires should clear without spacers, but best to double check
285/70/17 on trail wheels here with JBAs.
I rub hard at full lock. Red powder coat is gone where it rubs so it's bare steel on those areas. Just a heads up.
H.Sikina
