Thai
Elite Member
Here are some link for your viewing:
http://www.cs.cornell.edu/Info/Peop...eb-reviews.html
Here is an excerpt: (in case you need info right away)
"In case you haven't heard. Chryslers new Quadra Drive has a few annoying bugs that they haven't worked out yet. I have lots of names and letters from other owners that are experiencing the exact same problems as my car. There has also been some buybacks by Chrysler from owners who just couldn't get their cars fixed, and didn't want to put up with the problems anymore Yet Chrysler is still selling them with the bugs to new unsuspecting owners every day.
It seems that the two major problems in every Quadra Drive are a problem with a progressive coupling in the transfer case that makes the front wheels shudder rather violently when turning the wheels half way or more. When parking, making a U turn or just backing out of a parking space at a parking lot. The front wheels try to lock up like they are grabbing for traction. It's almost like a part time four wheel drive system turning on dry pavement. The dealers say it's a progressive coupling in the transfer case that should be allowing the wheels to roll freely but isn't. Their answer so far is to replace the complete transfer case. Which after a few hundred miles does the same thing as the old one did. This could turn out to be a safety item, which could cause an accident.
The second item which isn't related to safety but an extremely annoying problem that shouldn't be happening on a Jeep Grand Cherokee Limited that cost close to 40 thousand dollars. Chrysler built and advertised the Limited as a luxury off road vehicle. To that end they put many things in the limited that are meant to give you the feeling of a luxury car. Leather heated seats, automatic temperature control and other things that bump up the price an additional 8 thousand dollars over the Laredo model. Which works until you drive the car over 40 MPH. That's when the whine of the gears starts and the grinding of the bearings. The grinding is more of a feeling rather then a noise until you get up to 70 m.p.h. It's sort of like driving on rumble strips you find on the side of the road. After 70 m.p.h. it tends to get a lot louder. Then along with this is a loud annoying gear noise, which sounds like it's coming from the rear axle. The gear noise is loud enough on it's own to overpower the radio when set at a reasonable level.
So far Chrysler is saying the gear noise is normal for the Quadra Drive but I have heard trash trucks and tractor trailers that are quieter then this car. Their response so far is to replace both axles and the transfer case, which does not solve the problem. You just get a new drive train that does the same thing. There are people that had this done three times and or including rebuilding of the parts at the dealer, and the problems still exist.
My problem is similar except that I only have had things replaced one and a half times. The half being that the new transfer case they put in my car had a stress crack which was blowing fluid out all over the place. Interestingly the dealer never checked for leaks after the work was done. I got to drive it home and see all the transfer case fluid leaking onto my driveway. In that trip home and back to the dealer I did have a chance to notice that with all the repairs, the same old problems were still there. Now I am driving a used Mazda Protege loaner while I wait another week for a new transfer case. Even though I am still paying for a 38 thousand plus car."
