Jeep Grand Cherokee (horror stories!)
Couple more questions. I appreciate your knowledge on the 4runners.
1. On another forum there was extensive debate over whether or not Atrac remained active when the Center diff on a 4runner is locked. They agreed VSC turned off, but argued over Atrac. Do you know for certain one way or the other?
2. On competitor vehicles when switching to 4lo it they always seem to lock the center diff automatically. On 4runners can you operate 4lo without locking the center diff? If so it seems that toyota gives the driver more control over the system.
As for Jeeps I finally figured out some of their setups. These auto manufacturers sure don't make learning about their systems easy. You think they would advertise it and make the information more readily available as a selling point to people who bother to research before buying. 4wd is great, but more moving parts means if something goes wrong replacing something like an ELSD on a Jeep has to be more expensive than replacing brake pads or rotors. Anyway:
2004 style Jeep Grand Cherokee:
1. Selec trac - 2wd mode. 4hi which seems to be really AWD as it's fully in RWD unless the back slips. 4lo, which also locks the center diff. I could not find anything about any L/R power shifting and believe there is none. Both R tires spin = stuck.
2. Quadra Drive I - 4hi (again the rear awd setup), 4lo that locks the center diff, and vari-lock diffs for L/R transfer. Is the vari-lock the viscous coupling method?
2005 style:
1. Quadra Trac II - 4hi which behaves more as a 52/48 power split back/front and can shift power with slippage. 4lo which locks the center diff. Brake traction control system (BTCS) for L/R power transfer. They must have liked toyota's Atrac system and made a variation of it. Nissan also with the ABLS several years after toyota.
2. Quadra Drive II - 4hi (same 52/48 split). 4lo which locks the center diff. Instead of BTCS they use Electronic Limited Slip Diffs for L/R transfer using clutch packs, which I hear can be expensive to replace and you won't know if their worn out and broken until you need it and it doesn't work.
So it sounds like the 2004 Quadra Drive with the viscous coupling is not doing it's job very well. Does anyone have experiences with the '05-'08s with either the BTCS or the ELSDs? I wonder if they're any better.
1. ATRAC is always ON. No doubt about it. Anyone who says otherwise does not know what he/she is talking about.
2. Yes, more control. It is rarely useful, but 4-LO (center diff UNlock) may be useful when you're launching a boat or pulling a boat up the incline. Or if you're pulling a tree stump out of the way and have to make left & right turns.
Ive has a 93 ZJ 4.0 , Transmission went after 10 minutes of off roding, I had a 94 ZJ same problem with the transmission but after 120K miles. I will never buy another jeep as long as I live. Toyota for the win because Ive seen what they can do after owning one and really giving it a Top Gear Beating and it drove all of us home without even a check engine light coming on and thats a truck with 320K and was a hunting truck before I got it..
josh220 said:
Wow 10 mins, is that a joke? That's pathetic.
Well, an Xterra in our off-roading group had it's transmission clunk on the first hillclimb!
Shit happens...and sometimes, at the worst time.
Thai, is #2 correct? I cannot put my truck in 4LO unless the diff is locked first. Maybe once i locked the diff and put in 4LO, I can unlock the Diff??
On my 2002 4runner, i am almost sure that you can be in 4-LO withOUT locking the center diff...i am almost sure that you can do the same on 4th gen 4runners.
Same in my GX, I'm pretty sure it's discussed in the owner's manual.
Ambrose67
