rigtec
We have (2) JL Audio "HD-750/1 Mono-Block" Amplifiers. If you know subs, you know about JL Audio's reputation; these amps are MONSTERS! They'll provide a full 750W from 4ohms all the way down to 1.5ohms! They're clean and well taken care of. FREE S&H to anywhere in the USA (excluding HI or AK)! Price (Firm) includes ONE Amp and all necessary electrical hardware ('stacking kit' and 'Remote level control' included when buying both amps)!
CONTACT: [email protected] Serious inquirers only PLEASE!
Specs:
@ 4 Ω 750 W RMS x 1
@ 3 Ω 750 W RMS x 1
@ 2 Ω 750 W RMS x 1
@ 1.5 Ω 750 W RMS x 1
Frequency Response 6 Hz - 8 kHz (+0, -1dB)
S/N Ratio, referred to highest rated power >110 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
S/N Ratio, referred to 1 W (Main Channels) >88 dB (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Damping Factor @ 4 Ω >500 / 50 Hz
Damping Factor @ 2 Ω >250 / 50 Hz
THD+N @ Rated Power (Main Channels) <0.03% @ 4 Ω
Input Voltage Range @ RCA Inputs Switchable from 200 mV - 2 V RMS (Low) to 800 mV - 8 V RMS (High)
Min Copper Power / Ground Wire Gauge 4 AWG wire
Fuse Rating 60 A (AFS, AGU or MaxiFuse™)
Specs:
@ 4 Ω 750 W RMS x 1
@ 3 Ω 750 W RMS x 1
@ 2 Ω 750 W RMS x 1
