John's 99 4runner rebuild/build
mmml4
Started with this in August of 2007.
DSC01225.jpg~original
1999 4Runner, 2wd, 3.4 v6, auto. Killed in head-on collision.
Rebuild/build specs:
Replace frame, damaged body panels, damaged engine compartment components.
Front:
SAS with 80 series Land Cruiser axle and coils
3 link with panhard
Ballistic Fab adjustable coil buckets
IFS steering box
Rear:
3 link with panhard
Engine:
3.4 liter 5VZ-FE
Transmission:
80 series Land Cruiser A343F & transfer case running Slee Offroad part time 4 wheel drive kit and manual hubs
Tiptronic type manual transmission shift control
and a whole bunch of other stuff I haven't figured out yet
Swapping in the new frame.
DSC01489.jpg~original
DSC01491.jpg~original
DSC01492.jpg~original
DSC01495.jpg~original
DSC01496.jpg~original
It started out on leafs but I could'nt find a good steering solution.
After seam sealer, primer and paint. I searched and searched but could not find a really good match on the engine compartment paint.
DSC01882.jpg~original
DSC01887.jpg~original
Your basic frame plating, instead of plugging all the factory holes or plating over them I just cut mine to match so the space between the frame and the plate would be sealed.
DSC01350.jpg~original
DSC01349-1.jpg~original
DSC01287-1.jpg~original
DSC01286-1.jpg~original
My first attempt at building links.
Lower links:
I used 1-1/4" Johnny Joints (18mm thru hole) at the frame, custom sleeves with cruiser bushings (18mm thru hole) at the axle, 1-1/4" ladder bar adjuster for fine tuning and a custom square insert 6" long drilled and tapped 1-1/4" left hand thread 4" deep. Tubing is 2x2x1/4" wall.
DSC01903-1.jpg~original
DSC01907-1.jpg~original
DSC01905-1.jpg~original
DSC01904-1.jpg~original
Upper link:
I used 1-1/4" Johnny Joints (18mm thru hole) at the frame, custom sleeves with a cruiser bushing (18mm thru hole) at the axle, Ballistic Fab 1-1/4-12 righthand chromoly insert.
Tubing is 1-3/4" OD x .120" wall DOM.
DSC02009.jpg~original
Picked this up and now I got a rear to match my front .
97 Land Cruiser
70,000 miles
full floater
disk brakes
9 1/2" ring gear
63 1/2" wms to wms
DSC02022.jpg~original
DSC02023.jpg~original
Well I got my upper link tacked in place. I ended up with about 5" of separation at the frame and about 6" at the axle. My next step will be to fit the panhard.
DSC02024.jpg~original
Reusing the Cruiser coil perch.
DSC02025.jpg~original
DSC02026.jpg~original
DSC02027.jpg~original
DSC02028.jpg~original
DSC02029.jpg~original
As for the steering, stock power steering pump, IFS steering box, Marlin Crawler pitman arm, LC drag link. I wish I had taken pictures of fabricating the steering shaft but I didn't.
FIREWALL PLATE:
I cut the outer edge (about 1" wide strip all the way around with the bolt holes in it) off of the existing firewall plate where the steering went down to the R&P, I cut the piece with the shaft seal in it off also.
I then took a piece of 16 gauge sheet metal and formed it to fit the piece with the bolt holes and welded them together. I pulled a piece of string from the steering wheel to the steering box and took some measurements so I could fit the shaft seal piece to the new firewall plate.
Then I cut a hole for the shaft to go thruogh and then fit the seal.
DSC01888.jpg~original
DSC02140.jpg~original
STEERING SHAFT:
I cut up the steering joint that turned at the firewall and went down to the R&P so it would work as a u-joint, I used this joint at the steering wheel. I cut the splined section off of the factory shaft that the came with the IFS box and used a piece of 1/2" schedule 40 pipe to bring the shaft to length.
DSC02142.jpg~original
alexaturner
