JohnTx12
Like many people, I appreciate good headlights. Shortly after I purchased my 05 4Runner I started looking into doing a retrofit; something I had never done before. While I stretched the process over the course of three weeks (lots of part ordering and designing as I went) and many hours, I didn’t find anything particularly challenging. Hopefully, this guide will aid some people and give people some ideas. I primarily referenced (http://www.toyota-4runner.org/4th-gen-t4rs/183555-tins-mini-h1-retrofit.html) and then made up the rest as I went. I do apologize for any formatting or scattered images. This is my first guide I've ever tried to put together.
I recommend buying a second set of headlight housings, I feel like its relatively inexpensive and will give you the comfort of knowing you're not out a vehicle if you screw something up.
I bought and returned several items throughout the whole project but here is my final parts list:
Black 2003 2004 2005 Toyota 4Runner 4-Runner Headlights Headlamps Left+Right
G5 Stage III Parts Package
Bixenon Projectors:
G5-R LHD (3")
Compatible Ballasts/igniters:
Morimoto XB35 (35W)
D2S HID Bulbs:
D2S: XB 5500K
Shroud Style:
Apollo 3 Black Series
Wiring Harness: (match stock bulb size)
HD Relay: 9006/9005
Headlight Sealant
Gray: RetroRubber
LED Halos
110mm Pivot Switchback
High Beam: Profile HI-Lens LED
2 Pieces set 9005/9006 Headlight Bulb Xenon Halogen HID Light Connector Wire, Harness
Per the recommendations from Lightwerkz.net I went with the larger G5-R projectors, reason being, our headlight housings are huge and have the room. For the high beam side I went with the Profile HI-Lens LEDs which also serve as DRLs (30% power on DRL, 100% for high beam) I did not use any shroud on the DRL/High beam because there is almost no room for one and I think they look fine without one.
Step 1: Opening up the housings
Start by removing the four (4) perimeter screws, two (2) circular rubber seals, two (2) plastic vent covers and two (2) plastic mount clip.
I baked the headlights at 250F for about 8 min. I recommend gloves as they will be very hot when you first pull them out of the oven. Using a flat blade or other tool, pop the clips off around the housing. From there I just pulled the housing apart instead of risking damaging the plastic further with a tool.
NOTE: Once you separate the headlight lens from the housing, smooth the rubber sealant back evenly around the housing while it is still warm. This will make it cleaner to work with and save you a step when sealing them back up.
Next you can remove the headlight reflector bowl by loosening the two adjustment screws. Be careful with these as the heads strip very easily. Remove the low beam light shield by bending in the two metal clasps holding it in place.
Bixenon Projectors:
G5-R LHD (3")
Morimoto XB35 (35W)
D2S HID Bulbs:
D2S: XB 5500K
Shroud Style:
HD Relay: 9006/9005
Headlight Sealant
Gray: RetroRubber
LED Halos
