Bringing my truck back to life. We had our first child in Jan 2021 and bought a newer highlander in preparation for that. Given all the working from home with COVID, I had no need to really drive my truck. I let it sit for over a year with only driving it a couple of time. Finally decided to get it back in order. The odometer is at 168k and counting.
It's going to cost quite a bit to get everything done but definitely cheaper than trading in for a new vehicle. I should be able to get another 100k out of it after everything is done.
Work done so far:
- New Battery
- New cat-back exhaust, swept to the side, and replaced downstream o2 sensor on bank 1. The stock had rusted through in a couple of places, a crack in the muffler and the pipe after the muffler fell off.
- All new fluids with flushes, etc - Diffs, T-case, tranny, power steering
- new weatherstripping for tailgate glass
Pending
- New Halo headlight housings to replace the current ones with moisture inside and bad weather sealing
- LED Headlights to replace the HIDs
- New leather covers for bottoms of front seats
- New cup holder/tray insert for rear armrest
- new tires
- Rear end link replacement (current ones are snapped)
- AC repair (condenser needs replacing, will likely have them replace compressor too when they rip the dash apart)
- repainting Skid Plates, steel crossbars and loadwarrior
possible / longer term
- replace the upstream O2 sensor on bank 1 since I still have the p0420 code
- passenger cv axle may need replacing
- new suspension. I have about 120k on the FJ setup
- Assuming I'll need new pads, rotors and calipers after all the rust and sitting. May have a seized caliper but not quite sure yet
