killzones 2nd 1st gen
Yes it has a chain that someone put it in wrong. Ur harmonic balancer has rubber that holds the 2 parts together and over time the rubber slips and can come apart . It happens on any harmonic balancer over time
Interesting! I haven't ever seen a harmonic balancer fail on a 22re... or any engine for that matter. Usually the front seal will wear a ring in the balancer and cause the sealing surface to wear down and cause oil leaks. Never heard of the rubber breaking down though.
It's a good time to order the LCE underdrive kit! Come on... you know you wanna start decking out that engine!
found a ecu and put it in and now the 4runner is running rear good. I still have to get exhaust because it sounds bad but its running real good so now its time to start building everything else
well my buddy's runner was sagging real bad and he is cheap. So he went to Oreillys and bought a 3 inch block lift for 34 bucks and we put it on
