Knock Sensor Repairs - What did you do?
What parts did you replace for your knock sensor code?
  • I replaced only the harness and it fixed the issue.
    Votes: 3 27.3%
  • I replaced only the harness and it did not fix the issue, CEL was still on.
    Votes: 1 9.1%
  • I replaced only the harness and the affected sensor.
    Votes: 0 0.0%
  • I replaced the harness and both knock sensors.
    Votes: 7 63.6%
  • Total voters
    11
  • Poll closed .
I've not dealt with partsouq yet; but have used amayama from Japan several times with good results. Yesterday I ordered the following from amayama UAE:
2x: 89615-12090 OEM Denso knock sensors $98.75 ea
2x: 17177-62060 OEM lower manifold gaskets $22.49 ea
Shipping: $23.50
I'd ordered the wiring harness 82219-34010- $28.84 from Conicelli with a bunch of other stuff a week prior. No rush with delivery needed for me as I've chosen to replace these prophylactically as part of the VC gasket, timing belt and SC install work.
Thanks for providing these links! I was about spend about $188 from Mcgeorge!
Going to be replacing my 2 knock sensors and wiring harness here soon. As far as parts go, replacing 2 sensors, wiring harness, fuel injector o-rings, 2 lower intake manifold gaskets. Anything else I need to replace while I have everything off?
Gonna need a throttle body and intake plenum gaskets. Good time to do your valve cover gaskets too. I believe the O-ring for the banjo bolt on the fuel rails, or something along those lines, is technically non-reusable but I was unaware of this and haven't experienced a leak. Still might be worth looking into.
ghengiskhan
