L4 working, H4 not working
tevond
Howdy all, I'm new to this site so forgive any missteps. I've poked around quite a bit and haven't been able to find anything on this. I have a '93 4runner (w 22re). Bought it recently. Mechanic told me the 4wd wasn't working, but it turns out just to be the H4- L4 works fine. Any ideas where I might start? There are a couple free wire hanging out near the front differential (can't figure where to put them), would it be plausible for this to be an electrical issue?
Thanks!
Welcome to our forum! You have come to the right place, for all of your T4R questions. That being said, you have a 2nd gen 4Runner and thus, you really should post your problem in the "CLASSIC T4Rs" forum to get immediate and direct advice/answers to your questions. This current forum is for announcing yourself as a new member and being welcomed and unfortunately, not many members spend much time in this part of the forum. So, please repost your mechanical issue here:
Classic T4Rs - Toyota 4Runner Forum - Largest 4Runner Forum
and you should get plenty of help and advice! GOOD LUCK!
Thanks!
I suspect that your low range is working but your 4wd is not. Your transfer case has two input rails, controlled by your tcase shifter, and they don't talk to eachother so it's entirely possible to be in low range but not 4wd if there's a problem elsewhere in your 4wd setup. You probably have the Automatic Disconnect Differential, and you probably have trouble with the vacuum switch that engages the front diff and makes 4WD happen. Try this search and you should find what you need - https://duckduckgo.com/?q=site:www.toyota-4runner.org+add+vacuum+switch.
H.Sikina
