Lamin-X Fog Light Lens Covers
Loadedpocketz
Installed a pair of yellow Lamin-X Protective Film Covers on my fog lights. Pretty happy with how it turned out.
AAFB9473-8506-4D5D-A948-C80677DA2C44_zpsz6ywyecn.jpg~original
Agreed. I just put LED H11 bulbs in my factory fog light housings a few minutes ago. The lighting on the stock 4Runner sucks compared to my Lexus. Next up will be LED high/DRL bulbs and some type of conventional bulb for the low beams.
Agreed.
Are you running Lamin-x and the LED's?
Please let us know how the LED's work out in your fogs and which brand/model you are using, after you have had some real world use to share.
I am doing my home work on both the Lamin-x and the fog light bulb upgrade now.
No Lamin-x. Yesterday evening I went to a Christmas party and we didn't get 10 feet out of the garage before my wife said hey what is up with your headlights.....the road and ditch are bright.
I didn't get flashed one time from on-coming traffic and the road just in front of the 4runner and the ditches were lit up like never before. I'd buy them again for the price!
Since I have larger hands getting them in was a tight fit. The key is to unplug the connector before trying to unscrew them. The wiring doesn't allow it to turn all of the way to get the light bulbs out. Once I figured that out it was a 10 min job for both sides.
Here is what to look for. $21.99
Calais Extremely Bright COB Chips H11 30W LED Fog Light Bulbs Plug-n-Play(pack of 2)
4.1 out of 5 stars 547 customer reviews | 179 answered questions
No Lamin-x.
:thumb:
Did you use a Canbus Load Resistor warning error Canceller Decoder resistor as recommended by Calais?
https://www.amazon.com/dp/B01JYEFM8C
Or do they work fine with out it?
Also, how effective at reducing fog reflection is the yellow color led vs the white bulbs with a filter?
That's a great deal. Stupid question time...
A few different bulb manufacturers state their replacement bulb fits H11 and H16. I'm guessing these will work for an H16 fog light as well?
I think the h11 have a higher voltage output but they will interchange.... not a stupid question [emoji1303]
I did the covers but they started to peel around the edges. I used some heat as well. Not as yellow as I thought it would be.
I just put in some Baja design squadron pro in amber and they are much better.
lindwlson982
