Lamp is out on clock display
JeratBP
Member
Anyone know how to fix this? Turned my headlights on this evening and found display half lit. Is it just a bulb? If so, does anyone have the part#?
Yep. One screw holding the climate controls on, then they pop straight out as a unit. a quick twist with a small flathead srewdriver and the old bulb is out.
Replaced the first one, then the other side went out, along with the Low/Hi fan controls. Already rechecked my connections. Probably going to order new set of bulbs.
Every time I touch anything on the HVAC controls or around the HVAC, I loose another bulb; even ones that I changed recently. I change a bulb and loose another (or two).
