Lasfit LEDs - Review
It is normal for the driver side to be lower.
Not with modern headlights.
The reason for the stair-step cutoff line is that it effectively lowers the beam path for oncoming traffic while providing longer throw in front of your vehicle.
You can see very clearly what Toyota wants you to do. Both lights along the same horizontal plane.
If you really want to get into it, there are other sites that talk about different beam patterns.
Daniel Stern Lighting Consultancy and Supply
And you can see that even for headlights that both throw the same symmetrical pattern, the approach isn't one headlight lower than the other, it's moving the hotspot off center.
I need to do more research but from my understanding, headlights over a certain height (36? 39?) have a 2" drop at 25 feet, while headlights below that are aimed level.
Same site you can see he has measurements for when to lower 2" (up to 34.5"), 2.5" (35"-39"), and 3.0 (over 39" from ground). But when I did a bunch more research I found no consistency in what was recommended - it's all internet lore.
The only thing that is consistent is having the headlights at the same level.
Lasfit LEDs throw any abs error codes? I want to get this pro kit. Also anyone do drl/high beam replacemt from Lasfit?
I have had zero problems with my Lasfit custom 4Runner LED headlights. No ABS failures, no nothing. Just really good headlight action. I have not changed any other lights.
Year 1 recap:
- Still have not been flashed once. Literally not once.
- No oncoming cars have been sent into a ditch or innocent woman and
children killed
- Still an LED bulb in a halogen housing
- Still loving the output and driving at night with them is great
- Still haven't hit any deer
- No codes thrown
- No failures and they are always on even during the day
- Still haven't read that thread on TacomaWorld
Year 1 recap:
children killed
- No codes thrown
Ignorance is bliss isn’t it?
Not sure if Toyotas do this, but on the global platform Range Rover L322, the headlights have a switch you can flip to either have the driver side “cut down” or a straight line cutoff.
I verified and found a video that showed the other setting was indeed a straight line, and did not simply “flip the dip” to the other side. Is the asymmetrical dip US-only?
Fast forward to 7 minutes, interesting! Can we do this on 4Runners?
How to change headlight HID bulb / change beam pattern on Range Rover Sport 2005-09 - YouTube
Wow I knew these bulbs were just as bad as any junky LED H11 bulb on Alibaba but holy smokes I did not realize how much they were charging people for them. $538?! You can get properly designed BI LED projectors for less than that.
I really hope prospective buyers do their research and cut through the misinformation on this thread about this being a good solution. Or at the very least hop on Alibaba and pick up a similar bulb for $20 and get the same result.
delislerebecca
