Latest oil test on my Lexus
toyo
Member
I know its not my 4runner, but this is what happens when you change your oil every 4k miles with Mobil 1 and use a Toyota filter.
No earlier than 5,000 mile changes here... I got Mobil 1 waiting for spring oil change.
I change my oil no later than every 4,000 miles. I try to stick closer to every 3,000 because I only do around 14,000 miles a year. Maybe I am a little to cautious, but I don't feel comfortable sticking to what the book says, every 5,000 miles. Looks like it pays off to change your oil sooner than later!!
I did my first change at 1500 miles and have done the others at 3750 mile intervals. This is the interval Toyota previously recommended for severe service. I don't come close to severe service so by using Castrol GTX 5w30 and Toyota filters I am sure I am in great shape. Plus based on all of the oil analysis on www.bobistheoilguy.com the Toyota 4.7 V8 is very very easy on oil. I am planning on going to Mobil 1 5w30 and 5K mile OCI. I might do a oil analysis after running the Mobil 1 for a few changes. Very interesting oil analysis. Just shows how good Toyota is at building engines and how good Mobil 1 oil is. Thanks for sharing.
Pitbull, I would start doing your oil test now. The earlier you can start your trend base the better. I use Blackstone-labs.com. they do a pretty good job.
All independant test I have seen shows most oils about the same. Why pay more.
Mobil 1 might last 30K miles instead of 25K miles before breakdown but since you should be changeing by every 5K miles who cares. If oil gets dirty wont make any difference what brand it is.
I can promise you this. If I had been using regular dino oil for 128k miles my engine would not be in the shape it's in now. Mobil 1 and other "more expensive" oil keeps your engine alot cleaner. I have removed the oil pan, valve cover, I know what the inside of this motor is like. And that is why I will continue to waste my money.
Toyo, what do you think about this idea? While a vehicle is under the manufactures 5 year 60K mile warranty, use Toyota's recommended 5K mile OCI and dino oil. Then when the warranty is up switch to synthetic oil and run it 7500 miles. The synthetic should clean up any deposits and by the time you got to 128K miles it would be the same as the engine that used synthetic since 5K miles.
Interesting. Anyone heard of Amsoil? I was wondering what type of oil goes into my 2005 4Runner V6. 5W/30 10W/40 or what.. The motor is new with only 1500 miles on it.
I guess I should start now using Mobil 1 with such great results.....
I just rea my manual and I guess it is receommended that I use 5W/30 with a 5.5 Quart capacity fill when changing out the filter as well. SO I guess I can put in 6 Qts of mobile one?
Suggestion, wait for a couple oil changes using the regular dino oil then switch. Also if the owners manual calls for 5.5 Qts then only put in 5.5 Qts. Over filling is just as bad if not worse then under filling, it can cause oil foaming at higher RPM's. While under warranty follow Toyota's OCI recommendations so you don't invalidate your warranty.
10-4 Pitbull, just curious what is Mobil 1 going for these days??
$5 bucks a quart. I think I will wait for a few oil changes before I switch. Maybe 5 or so.
what do you recommend for 2nd gen's??? I don't remember what my dad uses (he uses a standard oil for all the rigs in the family he takes care of - which I think happens to be Mobil 1)
Yea, that will be fine Pitbull. I am just so damn anal. When I removed my wifes oil pan I was blown away at how clean it was in there. You know how most engine parts have that dark golden stain on all the metal parts. That is the oil vapors absorbing into the metal. My internals were like they were just assembled. Then when I removed my valve cover I had no idea what to expect. These engine have had some sludge problems as you are aware of. Some say even when maintained. When I pulled that thing off. I was amazed once again. Those cam lobes were as shinny as my teeth. LOL. Now, what I would like is too have an exact engine, exact OC shedule except with Dino oil and see what the difference would be. I could be putting Castrol GTX in there and it will prob run forever too, but I think it runs better for that forever with Synthetic. Did that make any sense at all.
I have 29 Diesel trucks I have to service today. It is 40 degress and windy today. I am going to be miserable. But at least it is a very profitable business.
I lived in the Atlanta area for 13 years, moved out in 1998. I bought my 1995 Landcruiser in Atlanta. It was on dino for the first 45K miles of it's life and then I switched to Mobil 1. At 90K miles I checked the valve clearance and it looked like new in there. I think the Mobil 1 does a good job shining everything up.
Amsoil?? NO THANKS!!! Start a search on teh web for Suzuki Bandits with cam problems. Only Bandits who run Amsoil have camshafts that wear out quickly. I run Redline and love it. Mobile is great too!
I change my RX330 every 4-5k miles. But then again oil changes are free for my Lexus.....To bad they arent for my 4runner....
If they do it for free, I would have them do it every 3K miles :) Enjoy the Lexus lounge have a Coke and a donut on them and chill-out. :D
Can you believe when I went to get my last oil change, they gave me a unlimited free valet pass for the Galleria in Houston.....
