LBJ Grease Zerk
Okay guys,
So I have been talking with my mech over the weekend and want to pass along what he is saying. Don't kill the messenger here if you disagree with what is being said and I myself am still learning. But again, this guy is a WELL KNOWN yota mech here in CO and works on a lot of the Rising Sun club rigs so I do think he knows his stuff.
According to him (and he even sent me some pics), his parts supplier (and all of them outside the dealerships) have to source OEM parts from Aisin as they can't get the Toyota branded ones. This is a LOT like AC Delco and Chevrolet although Aisin is owned 30% BY Toyota themselves. And therefore, Aisin is THE direct manufacturer and supplier of OEM Toyota parts (in BOTH the original/dealer and certified Toyota service sectors) for Toyota themselves. They build to OEM spec FOR Toyota. When they do this for the dealership route, they brand them as "Toyota" and sell them through dealerships only. And that tracks because as this forum has covered, you can really only get Toyota branded LBJ's through dealerships and a few other limited sources. When they build them outside of that for direct replacement part sale for certified Toyota distributer/mech supply chains, then they brand them as Aisin and they are NOT branded directly as "Toyota" and often are painted and/or changed slightly...sometimes only have a ground off portion where the "Toyota" moniker would be. But, apparently they are every bit up to OEM spec as actual branded "Toyota" parts for all the aforementioned reasons. And, you will even find Aisin branded parts on your original truck. And so, these LBJ's on my truck now are Aisin.
I also poked around and found some stuff around the web backing a lot of this up:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4113237/Re:_Aisin_parts_Genuine_Toyota
https://www.yotashop.com/brands/AISIN.html
30% owned by Toyota: https://en.wikipedia.org/wiki/Aisin_Seiki
So, anyway, I'm not claiming to know all this for certain but I'm putting pieces together and it's not as simple as I thought. But I do feel confident these are at least not moog or something like that and it's coming down to a trust issue with my mech here. I also think that you'd find that the Napa brand ones are likely from the Aisin factory too and probably not as horrible as we might think.
But then you all had to go and show me the Solo stuff...lol.
Man your mechanic has gotten good over the years telling that story. He is completely making all that stuff up.
Thanks for your detailed explanation! Please post pics of your findings on the OEM and aftermarket joints! I would be really interested to see a cross-section.
I also had a chance to compare products and I'm pretty sure Moog doesn't make their own LBJ's for this application. They just re-package the Sankei 555 ones, you can tell by the 555 stamping. As does Napa, Raybestos, and probably many other brands. Moog does have a lifetime replacement warranty, but what good is that if you're not checking regularly and the joint leaves you stranded on the road.
These aftermarket joints all have a metal-to-metal fit with a greasable fitting. The ball is not polished like on the OEM design and therefore the ball scores very readily even from minor movement. I wonder if these aftermarket joints would be ok to use if one were to grease them with moly VERY regularly? They seem to come standard with a very basic yellow lithium grease.
Well I am convinced. I'm going to talk to my mech and see what he can do and let him know that it's okay if he considers them OEM equivalent but when I talked to him and said OEM I meant genuine Toyota. I would have happily bought them at the dealership and paid him to install them. Now, his time is wasted and I'm unhappy with the end result. I may be out the $500 but we will see what he says.
But, unless he jumps on it it's going to be awhile. Luckily I don't put a lot of miles on my rig right now. Most say these "555's" should go a minimum of 15k. I'll plan to change them well before that sometime in the next few years / 10k miles.
TWO QUESTIONS:
1 - So is it extended wear that is the main issue...and time breaking down the liners etc. as outlined by ibhsbz above? I ask this because I'm trying to somehow factor in how much additional wear they get from wheeling. I do take my rig offroad...not the crazy stuff but I do take it on at least medium to medium difficult trails. Any insight on how anyone thinks wheeling affects the LBJ's would be of interest to me.
2 - Where is the best place to currently buy true, genuine Toyota packaged and guaranteed LBJ's right now? I have found some links on all the other threads but currently where are you guys sourcing these? Local dealer only or where online?
TWO QUESTIONS:
Honestly, if you bring this up with any mechanic, you'll probably end up sounding like a demanding prick because it will be hard for them to understand why you're making such a big deal over something so apparently insignificant. That being said, you should still get it done properly.
1. Wheeling will wear out any joint faster. Even though the OEM joints are the strongest, there is always still a chance of them breaking. I think the most common theme is people having significantly lifted trucks which causes the joints (OEM or aftermarket) to be consistently operating at a much different angle which over-stresses the joint beyond design. This is why I chose to stay with a humble 3" lift only.
I know the aftermarket joints are of lesser quality than OEM, but the fear mongering going on that you're guaranteed a failure is probably an overreaction. If you're operating them at stock angles, chances are you'll probably be ok for a while as long as you're regularly checking for play in the joint.
2. Either local dealer, or any online Toyota OEM parts supplier that is based off a real dealership location. Even eBay is fine as long as it's based on a real dealership. The only places that can get this OEM joint are Toyota franchise locations.
That's really good info on the actual difference in build between OEM and the rest- thanks for explaining that [MENTION=78704]lbhsbz[/MENTION].
I got mine from OEMPartSource; most guys here go through Camelback Toyota. I Googled the part numbers, and went with the best price shipped I found.
All good info and fair I think. Ya, I mean I really do think this guy is honest and over the past year he's done a lot for me and saved me a lot of money. I don't think he's out there trying to intentionally swindle people on LBJ's etc. He can't get original OEM parts from his supplier and gets the next best thing in his opinion. I had been reading the forums and when I mentioned OEM I assumed he would know what I meant. And to be fair, he did pause on that point and talked about his part supplier etc. but we still didn't end up on the same page. The end result was not what I wanted but I think it was more of a miscommunication and probably him misjudging me as not as picky as I am (and I am.)
He's a good guy and I have been using him for a lot of work, and sent a few other folks there so I bet if I insist here he will do something for me. We'll see. At this point though I really don't mind doing it myself so that I know how it all comes apart anyway...I did that with everything on my Jeep and now I'm having to relearn it all on the 4Runner. The only difference is that back then I had a lot more time for this stuff than I do now as life responsibilities have increased.
As far as lift, that's what I have 3" Toytech with 1" body.
I guess they went up a little.
Order them from Camelback, free shipping over $150, not sure if that includes Canada but even if you pay $20 shipping it'll be worth it.
Keep in mind our dollar is at $0.77 of yours ;)
It's funny how the CAD has zero bearing on the americans but its HUGE for us up here. Everything in the states is super expensive now!!
Yea, he might not be a D-Bag. My old mech looked surprised when I told him not to use Moog parts in my T4R. He thought they were a good brand. Maybe they are for American vehicles? I dont know.
Most people dont belong to car forums. Most people just want their cars/trucks trucks fixed fast & as cheaply as possible. Most people dont keep their vehicles as long as we keep our 4runners. I'm guilty of using Napa parts on my last 3 daily drivers because I dont keep them that long.
Yep I think you are spot on. We are the picky ones and personally I think that's justified especially on a lifted vehicle like most of ours are etc.
And, I'm happy to report that he wrote me back yesterday and said that he'd be happy to redo them free of charge with the originals! He thanked me for my past and continued business and referrals and said no problem. Just need to schedule it up.
So...cool. Only now I'm wondering if I shouldn't just do it myself and more just to learn it. So we'll see.
Moog is making their own...not reboxing 555. Both metal on metal, but very different designs. The moog uses a 2 piece ball stud, the 555 a single piece.
seltzernator
