Lbz egr delete and tuner
Wtycackle
I am about to order an EGR y bridge delete kit for my 2006 duramax and I was curious to what tuners will be a good choice after I delete it? Any ideas?
After installing the SPELAB lbz egr delete kit, I'd prefer using the H&S Mini Maxx tuner. It's a great choice for Duramax trucks, especially post-delete, because it has pre-loaded tunes that can adjust to new setup. It offers on-the-fly tuning, so you can switch between power levels depending on driving conditions.
based on my experience, the best EGR delete kits are the ones that keep sealing integrity under high EGT cycles and don’t disturb the factory coolant pressure balance. After deleting mine, I paired it with an updated DOC/DPF flow check and corrected the torque-to-fuel tables, which cut down on soot load spikes during moderate acceleration. I also monitored pre-turbo EGTs and saw a more stable curve under towing. The results were consistent mainly because the tuning matched the hardware changes correctly.
used car modification parts from SuncentAuto
AndiGarage
