NJCatalana
Just noticed a leak coming from somewhere on my A pillar, has anyone ever dealt with one in this location before?
Sent from my SM-G965U using Tapatalk
Seems too high to the the windshield seal.
Silicone up the holes through your roof for your roof rack. I had the same problem on the passenger side.
I know there's a hole under the plastic endcap in the front of the roof rack, right above where you're referencing, start there and work your way back.
Go the extra mile and silicone every hole under the bolts that hold the rails in for good measure.
Do you have a sunroof? possibly sunroof drain tube?
Yep sunroof drain hose where it connects to the nipple. Just had this problem. Snipped a little of the end and put a hose clamp on it.
From what you're saying, I'm assuming that you disabled the drain tube? If so, where/how does it drain now?
