Lean after lift question
So the part numbers are different between left and right? Is this for SR5 or Trail?
I can't comment on the numbers, I've never looked and I don't care to do so now. I base my comment on a massive amount of pre lift research coupled with information obtained from aftermarket suspension vendors. Struts are the same, driver front coil is slightly heavier rate than passenger.
What suspension setup is this?
ToyTec Ultimate kit with 700 pound front coils and superflex rear coils. I would go with the 3" rear coils over the 2" rear coils. 2" coils gave it a negative rake, wasn't happy with it. Here are pictures with the 2" coils and then with a 3/4" spacer added on top of them. These pictures were taken right after the install when I still had my 285 KO2's on it.
I have 2019 TRD with 3" Bilstein 5100 + Toytech RCC2.0 lift kit and SPC UCAs. I have the dreaded drives side lean (was likely there prior to lift). With the lift the lean is pretty big, was 7/8" on full gas tank. I installed 1/4" trim spacer but it only seemed to correct the lean by 1/4", not the 1/2" I was expecting. Any thoughts on why I didn't get more lift from the 1/4" spacer?
