Leaning bad! Help me out!
Russalgolding
So I installed a small lift yesterday. 2.5" in front 1" in the back. The lift is the "spacer style" after installing I noticed that the 4runner is now leaning towards the drivers side. By about 1 3/4" I have check everything and it appears that the installation was done correctly. What am I missing???
thanks
Russal
long time reader 1st time poster!
if you took the springs out to install the spacers you probably got the springs mixed up. the springs in our trucks are sided dependent. no i dont know how to identify the sides on the stock springs but somebody else here does
what is your year, trim level, engine size or just the color codes on your springs. This will help diagnose.
pics of your front shocks would also help.
are your rear coils properly seated?
even with my icon lift properly installed, i lean about 1" on the driver side.
ALL 4th gen Runners have the 1" driver side lean, when lifts are installed. A 1 3/4" lean is much more. Swap the rear coils. Then, when you have enough money, install a suspension lift and retain your rear, driver side spacer to eliminate the lean. Good luck.
044runner4
