Learn More About the A750E transmission
AuSeeker
Elite Member
If you're like me and want to know as much as you can about your T4R, read this article in "Gears" starting on page 4 to learn more about the A750E 5 speed transmission....
http://www.gearsmagazine.com/resources/issues/e457d_2010_4_all.pdf
The first thing I learn was that feeling of getting rear ended when coming to a stop which most contributes to the drive shaft needing lubing which is a common issue could also be from the transmission falling out of gear due to low pressure and then slams back into gear after the transmission ECM drives up the pressure, this is caused by a faulty SLT pressure solenoid, replacing the solenoid fixing this issue.
charlesz
