LED for Daytime running lights
CVT310
Hi I just purchase some JDM led lights for my daytime running lights and blinkers. When I installed them it did not turn on. I did some research and some people wrote that LED won't work because they act as your turn signal blinker. Has anyone had any luck finding a LED bulb that would work? Thanks for the input!:pray:
you should be able to splice into the line without any addition and use your new lights as an aux. but if you wire them in as the only DRL and turn indicator you will get fast flash and will need to use a resistor. there isn't any reason why they wouldn't illuminate otherwise though
AndiGarage
