LED headlights?
Also just purchased Morimoto XB LED fogs 1,200 lumens each
Toyota: Morimoto XB LED Fogs (Round) - LED Fog Lights from The Retrofit Source
All of this for about ~$320
Can you confirm that these Morimoto XB's will work? The tabs in the diagram look to be symmetrical whereas the 06-09 fogs on our trucks I believe are offset. Mine are aged to the point the I would like to get new housings and will go this route if it is possible and confirmed they will work.
I already have a set in my wife's MY19 4Runner and would buy these for mine as well.
Those XB's didn't work as stated from TRS. They weren't 'bolt up' would have needed some fabrication bracket or something. I'd look into Baja Designs Rogue and I've heard using the Tacoma brackets can work.
Strange for sure. We've seen some that fits like OEM and some with gaps. The ones with gaps, used their stock OEM brackets and it made it a lot better.
erinobr2000
