LED Interior- Combatting Hotspots
LINY4Runner
Behold; my hotspots!
I used some crafty methods to fix the hotspots;
This Is the ECT button- it has a sort of clear plastic column in it that directs the light to the lettering, but it doesn't channel the light to fill the entire button- so I wrapped the four sides in tin foil- while leaving the ends open:
For the HVAC controls the hotspots were caused by the direct light from the LED, so I blocked the top of the bulb with a small piece of tin foil, and surrounded the bulb with scotch tape to help dispurse the light evenly:
These are the bulbs from the gauges. I again used tin foil, I shaped it like a U over the top of the bulb to, again, block the direct light- but still allow light to escape the sides. I then wrapped it in scotch tape as such:
Here's the interior all together after killing off the hotspots;
Have you considered the led strip? I've heard this on the backing spreads everything around nice. I think I'm about to get some for the headlights and interior.
Ribbon LED Strips
I thought about it but I wanted something that was direct replacement and plug'n'play.
Also if you look at my HVAC controls with the faceplate off- you'll see there's different "cells" for each knob.
I think you'd still have hot spots with the strip- just a whole bunch of them...
Be a pioneer! Post pics when you do it!
yeah man those turned out way better then with what i did. I just covered the hole thing with tin foil and im still getting some minor hotspots. How long did it take you to experiement with this?
Does want: even light distribution
Does not want: Mileage
Lol
