LED Light Bars & Pods
Do you have Lumens ratings for the XT series?
I am trying to decide between the XT series and TrekPods.
I want to add flood lighting to the front.
Definitely.
See below for a list of each light's LED type and Lumen rating.
Sorry for the late reply, I'm in Maine on business and haven't been at my computer all day.
ES Series TrekLight LED Light Bars
7 Inch TrekLight ES - 3W Epistar LED's - 2,500 Lumens
13 Inch TrekLight ES - 3W Epistar LED's - 4,500 Lumens
22 Inch TrekLight ES - 3W Epistar LED's - 7,500 Lumens
33 Inch TrekLight ES - 3W Epistar LED's - 11,250 Lumens
42 Inch TrekLight ES - 3W Epistar LED's - 15,000 Lumens
XT Series TrekLight LED Light Bars
4 Inch TrekLight XT - 3W CREE LED's - 1,600 Lumens
6.5 Inch TrekLight XT - 3W CREE LED's - 2,800 Lumens
9 Inch TrekLight XT - 3W CREE LED's - 4,500 Lumens
12 Inch TrekLight XT - 3W CREE LED's - 5,700 Lumens
18 Inch TrekLight XT - 3W CREE LED's - 8,600 Lumens
22 Inch TrekLight XT - 3W CREE LED's - 10,000 Lumens
36 Inch TrekLight XT - 3W CREE LED's - 18,500 Lumens
TrekPods
TrekPod OctaPlus (Round) - 3W Epistar LED's - 1,600 Lumens
TrekPod OctaPlus (Square) - 3W Epistar LED's - 1,600 Lumens
FloodPod - 3W Epistar LED's - 1,000 Lumens
TrekPod Mono XT - 10W CREE LED's - 900 Lumens
TrekPod 4x4 - 3W Epistar LED's - 2,800 Lumens
TrekPod Quad XT - 10W CREE LED's - 3,600 Lumens
[MENTION=90521]treklights[/MENTION]
Troy,
How much amperage do your lights draw? I'm working on a wiring diagram to run the lights as I told you. Check out the thread below:
http://www.toyota-4runner.org/classic-t4rs/133758-electrical-gurus.html
Hey SV,
Funny you should ask, I had these hooked up to a tester the other day.
The 4" XT's were drawing just above 1 amp at 12 volts.
The 18" XT's I believe were right around 6 amps at 12 volts, but I'll have to double check, as I don't remember exactly.
Troy, are there plans in the future for any "combi" series lights? I'm interested in a flood/spot combination for a ATV.
You guys are quicker on the draw than I am today!
I blame it on the flu I'm currently nursing.
Starting today, all ES Series TrekLight bars are available in spot/flood combo beam. :)
Guys, you'll have to excuse my idiocy.
I was messing around with an XT Series TrekLight Bar today and found out that the mounting points DO in fact slide from side to side!
There's a little bit of play when the mounting points are on either end of the bars, so mounting to something slightly wider than the mounting range should take up the last of that slack.
Here is the mounting width range for the XT Series TrekLights:
4" TrekLight XT: One mounting point (can be moved all the way left or all the way right along the bar).
6.5" TrekLight XT: One mounting point (can be moved all the way left or all the way right along the bar).
9" TrekLight XT: One mounting point (can be moved all the way left or all the way right along the bar).
12" TrekLight XT: 1.5" apart to 8.75" apart
18" TrekLight XT: 1.5" apart to 14.75" apart
22" TrekLight XT: 1.5" apart to 18.75" apart
36" TrekLight XT: 1.5" apart to 32.75" apart
More like 80/20.
The inner lights (80%) are spot, and the outer lights (20%) are flood.
Are they operated by the same switch where they both come on at the same time or is there some kind of dual control?
You may have changed my entire plan
This option is not showing on the web site yet.
Sorry to throw the monkey wrench into your plan!
Same switch. The floods and spots do not operate separately. The only thing that's different is the shape of the reflectors.
TrekPod Mono XT Night Shots
Low Beams:
ONE TrekPod Mono XT Spot Beam:
18" TrekLight XT Night Shots
Some TrekLight eye candy:
18" TrekLight XT Spot Beam
Obligatory "Twin Trees" Shot
Into the sky. Notice how there's enough spread to shine a bright light onto the trees, while throwing a killer spot beam into the sky:
Into the Woods:
So, I'm thinking about opening the GB up a little early since the other one is already over.
What do you all think?
Anyone itching to reserve a light?
I might have missed it, but what sort of pricing/discount are we looking at on the GB? And how long will it run?
Hey Troy
I am interested in the Flood/ Spot combination. Any chance of the XT series having the Flood/ Spot combination?
What does the combination do to the lumen rating?
I am leaning towards the 9" XT if it can be made the combo. I think that would give me the lighting I want in the front.
Hey Troy
Sorry DF, no combo beam for the XT Series.
However, spot beam LED light bars have enough spread to satisfy most people's flood requirements. Perfect example is the picture of the 18" TrekLight XT I posted yesterday. Crazy spot beam into the sky, with enough spread to light up those trees like Christmas.
I think you'd be happy with a spot beam, but if you need both patterns and you're set on the XT series, a 9" XT Spot with a pair of 4" XT Floods will do the trick.
7ron
