LED Running/Day lights Mod 1998 SR5
jwillo7
I've had them for a couple years. They need to be wired. You need to buy new sockets which you can get from ebay for around 5 bucks. They have 3 wires coming out. You connect 2 of them to the existing blinker wires and then the third is the the power for the drl white light that you connect to a wire that has power when the ignition is on.
oh ok thanks i was confused as to how these things work but that would make sense. i did some more searching and i think this is more what i was looking for. looks like it comes with a harness and relays. but i don't think the factory housings for the turn signals are very reflective like the corner or headlights are. is that a problem or would clear lenses work?
6K WHITE AMBER SWITCHBACK V3 TRITON LED SYSTEM 1156 | 1 PAIR - 1156 LED - Shop Bulb#
is this what you have installed on yours? appreciate the help!
I have a tower type bulb similar to your first post. They discontinued that bulb though. I have the 99 blinkers so the bulb sizes are different I believe between the 96-98 and 99-02. The only thing they have now for the 99-02 is the v3 triton which is kind of expensive to me but are supposed to be the brightest possible. I paid $35 for my bulbs from vleds. If you don't have clear blinkers, I would recommend them if you do get these since the stock blinkers outer lens is the reflective orange, and the clear blinkers would have a more reflective inside than the stock blinkers for a '98.
that's kinda what i thought about the housings for those turn signals. yea looks like ill be close to $200 for this little upgrade might have to wait a bit considering i just ordered my HIDs. thanks for the help man! i'll post a pic to this thread if and when i decide to do it.
MikeV5280
