Level 8 MK6
This is pretty much what I want to do 17x9 et-12. Wondering if 285's will fit??
17x9 -12 wrapped in Falken Wildpeak A/T3W 265/70/17
Minimal rubbing at full lock, just a little more minor adjustments & it'll be good. It doesn't bother me that much, I'll probably get around to trimming the bumper & modifying the mud guard over the weekend.
After taking my rig through some tight trails the lip and spokes on these wheels do get a little marred up since they stick out a bit more compared to some other designs.
I have the matte black level 8's on my 99 and the finish on these wheels just doesn't hold up. If you have time to rotate your own tires every time and don't do any wheeling you should be fine. I have had to invest in sharpies to keep them looking good.
Not a huge fan of the center caps... oh well, maybe I'll paint them
17x8 0 offset 275/70/17 BFG KO2s
Here are mine on a 2016 TRD Pro with 275/70/17's and a toytech 1" front spacer.
I'm guessing the difference between the 21133 and the 21134 is the 33 is a set of 20 and the 34 is a set of 24. Is this correct? Thanks
Just browsed through all the pages. Might've missed it, but wanted to confirm these wheels fit 275 70 17 BFG KO2 tires with Bilstein 5100 set at 1.75 front and 1" rear spacer? Is 0 offset recommended or is -10?
I don't know about with the lift but that's exactly the setup I got with factory suspension. Had some rubbing that I fixed with a small mud flap trim and the fender liner mod.
Are these the right lug nuts for the MK6? Does the small diameter work with these wheels or is there a large diameter lug nut that works better? Thanks
https://www.amazon.com/Gorilla-Auto...&sr=8-1-fkmr2&keywords=gorilla+lug+nuts+21133
When I purchased l my 17x8 0 offset MK6s in black. Discount Tire Direct sold me these and they fit my '16 limited 4X4. Gorilla 21134BCD. The link you provided on Amazon, and even Amazon's 21134bc's I have, don't show they are compatible with my vehicle, but they are. Go figure.
[/QUOTE]
Sent from my iPhone using Tapatalk[/QUOTE]
Yeah I was a little worried that the small diameter didn't quite fill the lug hole as good as the factory one does on the factory wheel since they are so small.
I installed the TRD (silver looking) center caps, but after several days, just did not care for the bling, may do something else to them. In the meanwhile, painted the stock caps black, happy at the moment, lol.
image url
I just bought the P265/70/17 Falken Wildpeak at3w from Discount Tire Direct ebay sale $532 - $100 savings for $432 with fee shipping. (coupon good through 3/17 for tires and or wheels $450 or more). I have no lift yet just bought my 4runner on 3/10 but only planning on 5100's at .85". Should I go with the MK6 17x8 0 or -10 or should I go 17x9 -12?
tuṣṭāva
