S p a r k y
How does a 1" thick spacer provide 2" of lift?
I'm not gonna explain like most do on here. But its true, the front doubles when you add a certain thickness. The rear is true 1-1
The 2 bolts by the wheel or the eccentric bolts to adjust alignment?There is no reason to loosen the bolts on the lower control arm. I'm not sure why anyone would even think that needs to be done.
Either way I did my daystar lift this way, the second time around. Its so much easier/faster, that its a no brainer in my opinion. The first time I removed a bunch of extra stuff, used the factory jack to push the A arm down (wedged against the top inner wheel well), etc. It was a lot more trouble and took twice as long.
When you can't take a 3ft. Prybar and pry the lower A arm down or even stand on it and have it swing down out of the way, you need to loosen the bolts. If you can get away with not loosening them, do it! You're really lucky! YOU WILL NEED AN ALIGNMENT ANYWAYS! I think it's bad advice to tell people to cut corners and to not touch the bolts and spend over an hour trying to pry the lower A arm out of the way when they can mark a bolt and get the alignment close to where it was instead of taking the minute to make it easy to swing the lower A arm. The truck should not be driven far till you get an anilgment. It'll be about +1.5 degrees camber (yeah, that's huge when it should be -.4).I was talking about the eccentrics that adjust the alignment--there's no reason at all to loosen them to install spacers. I think it's bad advice to post a write-up when something unnecessary like that is included
What I found was when I loosened them, the eccentric didn't even turn out of alignment. Maybe I'm lucky on that. The alignment was still way cambered in by the way. I fixed my illustration.
Has anyone installed a kit like this on a T4R with XREAS?
I wonder if this kit can be installed with XREAS since it requires a 60-degree rotation of the top plate. Wouldn't the shock also be rotated the 60 degrees, along with the XREAS plumbing? Is that a problem?
I'm sure I didn't explain that very clearly, but hopefully someone can catch my drift and explain.
Thanks,
Bill
Your alignment must have been jacked before. There's 0 chance that you can lift it that much and have it in spec still.
Yes, I have XREAS and it's not a problem. The XREAS systems is connected by rubber hoses at the shocks, so taking the shocks out and rotating them is not an issue at all. I installed my spacers without disconnecting the XREAS system at all.
Thanks Doc!
I've been thinking of a one inch leveling kit (half inch spacers) but it seems like the 2-inch kit (one inch spacers) might be easier to install. This next weekend I'm going to put a jack under the front and see what 2" will look like.
Bill
Two points:
1- you don't need to pry anything with a prybar. You can use the bottle jack that came with your 4Runner on the control arm. Try it next time, it works perfectly.
2- I installed a small leveling spacer on my own 4Runner. When I put it on the alignment rack, it was still within factory specs. So I did not need to adjust the alignment at all, but I did put it on the rack to check it.
A couple of questions if I could trouble you, as I am about to add 1/2" spacers to my T4R:
1) Which is the control arm?
2) Step #1 in the Diagram, are the two pointers referring to the large bolts to the right of each of the two pointers?
Thanks very much!
Sorry, forgot to add---- there are some really good step-by-step instructions posted on this forum to install spacers. I'll see if I can find a good one for you and post a link to it.
For step one it'll be obvious when you look. BY the balljoint there's 2 bolts on the bottom of the piece of metal The head is on the bottom and they're vertical bolts. Just pull those twoA couple of questions if I could trouble you, as I am about to add 1/2" spacers to my T4R:
Thanks very much!
