Leveling kit for 2015 Trail and 33's?
B.strouse
I am new to this forum and just wanted to get some info as I am looking to lift my runner. I would like to get 3" of lift and 33 inch tires on it. I was just wondering if I do a 3" leveling kit would a 33/11.5/17 tire fit on my runner without rubbing? Any guidance or advise is appreciated. TIA
I think you should be ok but if anything, the only place you would have to worry about if the lower portion of the bumper in front of the wheels. There is actually a bulletin for us techs to cut a bit off the TRD Pro's lower bumpers due to the stock tires rubbing. You barely notice it after they are cut. As info, I did a 2.5 front only lift on my 2014 SR5 and it leveled it perfectly if not a tad above the rear. Looks much better, rides great and a fairly simple task. Don't buy the plastic lift spacers and no need to spend more than $60-$70 for them as they are the same as the expensive ones. Ebay has a bunch and good price too. No need to install the sway bar drop either. And lastly, get an alignment right after because your caster, camber and toe moved a lot. A 2.5 inch lift changed my camber to the max it could go.
First off, your 2015 is no different than a 2010... so the same info applies to all 5th gens. There are some very minor differences in the bumpers.... but not enough to make a difference.
Yes, 33s can be run with no issue as long as you lift it, align it, and push the front fender liner forward a bit. Are you wanting to put on a new suspension or just spacers? Do you want stock wheels or aftermarket?
What do you plan to do with the truck?
Heres my 15 with a 2.5" daystar front and rear, and bilsteins front and rear with 295/70/17. This is my definition of perfect quite honestly.
