Leveling kit with STOCK tires/ Pictures???
Just got a black 2013 SR5 4WD and I'm debating between a front end only level or a 2.5/1 lift. Would anyone have pictures of both with stock tires? I'll eventually upgrade the tires but they still have plenty of tread so not till those are ready. Thanks!
Mine has 3" spacers in front 1.5" in rear still with factory tires. i'll try to get picture for you on level ground tm
Here's mine with stock tires and 2.5 front, 1.5 rear. Which meant the rear was1" higher measuring at the fender, but measuring at the frame it was level. If you do the 2.5/1 it might have a slight reverse rake at the frame.
Roktoy love the rims !!
OP, Im running stock size BFG's with a 2/1 lift. I think it looks fine. My new lift (Toytec Ultimate) should be on in the next week or 2 which will be a 2.5"/1.5 inch , but I'm going to keep stock size tire since I don't want to deal with any rubbing issues at all off road or on road. All I'm going to do is put on aftermarket rims.
Top is stock.
Middle are Bilsteins set at the 2.5" notch with no lift in the rear.
Bottom is with 2" lift ( I know you're specifying 1" though) in the rear. Keep in mind, the front is not this tall in person. It's still the same as the middle photo. The ground was angled downwards I guess.
2012 4Runner Limited Shocks
hey guys, I am need of some advice, my shocks & struts are toast according to the dealership. I want to replace them but not with stock, something with a little lift. i have been looking into Bilstein 5100's but not sure what to order. Also, if i order all 4 shocks, do i need struts too? Totally new to mods, so anything will help.
Good thread, I'm sadly considering going back to a smaller tire size, this is good to see.
I know they are not stock tires, but they are stock tire size. 265/70/17 C Rated K02s... Just had the 1" Cornfed front spacer installed.
Fronts: Part # 24-196499 (x2)
Rears: Part # 33-187174 (x2)
Check out amazon 4wheelparts total automotive
Most places are around $360-370 w/shipping for the set of 4.
You do not need struts too.
A vehicle will have either a shock or a strut at each wheel, never both. ... The major difference between shocks and struts is that a strut is a structural part of the vehicles suspension system where a shock is not. A strut is also crucial part of the vehicles steering system and greatly affects alignment angles.
Wow that looks awesome. I definatly wouldn't mind this look.
Toytec 1” Baja perch spacer level
Installed Toytec 1” Baja perch level. Rides great and looks like it should from Toyota
I just picked up mine after a 3” lift today. Still on stock shoes. I’ll snap a pic tomorrow.
Great thread I'm actually just in the process of choosing between 265s and 275s and I think this might have helped me choose the 265s
wayblom
