Leveling kit with STOCK tires/ Pictures???
Cornfed spacers for sale
Just got a black 2013 SR5 4WD and I'm debating between a front end only level or a 2.5/1 lift. Would anyone have pictures of both with stock tires? I'll eventually upgrade the tires but they still have plenty of tread so not till those are ready. Thanks!
Hey OP, if your are interested I have a set of Cornfed 2”x1” for sale, hit me up if you are interested.
Sometimes they do look a little too small
Anybody have 22 inch rims with 285/45/22 tires? I have a 2016 4Runner Limited 4x4 fully stock. Time to get new tires and wanted to get bigger rims and tires without doing a lift.
For everyone's reference. Here is what stock tires look like on a 2" front and 1.5" rear spacer lift. I aligned the cars' scale and levelled the photos at the hubs for your convenience.
It ended up lifting the truck and cut the rake in half. (still some rake, which I wanted) Will be upgrading to 275's or 285's soon. Will post another comparison shot once finished.
Part numbers!
Very nice setup.
Which Bilsteins did you use and did you only install shocks with the top spacer on the from and only shocks in the back?
If used additional lift components which ones?
Thank you
Chris
Top is stock.
Middle are Bilsteins set at the 2.5" notch with no lift in the rear.
Bottom is with 2" lift ( I know you're specifying 1" though) in the rear. Keep in mind, the front is not this tall in person. It's still the same as the middle photo. The ground was angled downwards I guess.
anyone know the stock measurements? trying to see how this would fit my one car garage at stock heights see photo
Here's stock tires with 1" leveling kit up front. No rear lift.
Running 275 70 17 KO's, and notice just a little shake in the steering wheel that starts at around 25mph, and goes away around 35mph. Slight, but noticable. No issues above or below that. Pretty sure it's just a balance issue, and would likely exist with any similar tire.
Sorry for the slight thread hijack.....
2017 TRD offroad
Bilstein 5100 set at 2.5 inches (front)
Rear bilstein 1.5 inch spacer and bilstein 5100 shock.
I have the front bilstein levelers and diff drop kit if your interested in them DM me .
Does anybody know why the Limiteds have different front coil springs left and right? Noticed this when detailing the rig. The driver side has more coils (not sure what to call it) than the passenger side. I'm guessing to help compensate for the driver's and gas tank's weights??
IMG_0886.jpg Driver side
IMG_0887.jpg Passenger side
Our Limited is also riding very rough even when the roads aren't that bad. The vehicle is very jarring going over the slightest road imperfections. All stock and running 32 PSI all around. Not even 8,000 miles on a 2017 4x4... Definitely need some insight!
charlesz
