Lift advice, HELP!!!!!!
JohnBill53
I'm thinking about getting the toytec 3" front spacer and rear coil kit. I have a 2001 4runner with 185k on it. I'm worried about the rake situation, can any one help me explore my options within the same price range? ($300-$400). Another question i have is going that rout, how big can i go with the tires?
OK there are sticky's in the 3rd Gen section. that discuss the lift options and the tire options. Personally if you plan on off-roading I would hold out until you can get a full OME suspension and not go with a spacer up front. Stock you should be able to fit 265/75/16 tires and same size with the kit you are looking at doing. I think you would end up rubbing to much with a 285/75.
workingwheelswnc
