Lift coils or top plate spacer
jonb2
Member
Hi all. 2007 4runner 2wd. Trying to decide between front lift coils or top plate (ie Daystar) spacer (not preload). Vehicle is used 99% daily driver.
Any thoughts which way to go for about a 2.5" front lift as far as smooth street drive?
thanks!
thanks!
Are you just leveling it or are you lifting the rear as well?
Are you sure you want 2.5" in the front? Is the 2wd 4Runner lower in the front because to level it usually only takes 1".
Thanks for the reply. Yes rear is lifted about 1-1.5" with Daystar rear spacer to correct the driver side lean (which works).
2.5" is what I need to lift the front and leave a little rake to it.
thanks.
utkrstam
