Lift install problems
NewfRunner
Hey everyone,
I know there's a million and one threads about lifts but I can't seem to find anything on a few things..
been lurking here for a few years, I have researched a fair bit and have been trying to wrap my head around things. I have no more mechanical experience than changing a tire, so bare with me. I have a 2005 Sport Edition, and I'm looking to lift. Didn't think it would be a problem, I drive mostly on road, a few woods roads now and then but nothing major. Looking through here it seemed a breeze to get a simple spacer lift/level kit installed, so I went ahead and got new tires, 265/70/17 Wrangler Territories. They rub on my stock vehicle, so I ordered a level kit. Locally (within 400km) I have found one option, ReadyLift. So I ordered it, and the local shop said about 3 - 4 hours install. Not bad, but having no experience I'd rather get someone else to do it. Fast forward to today, brought the rig in to get it installed and two hours later I get the disappointing phone call that they can't install it. They said the lift kit doesn't fit, and if it did fit the line running from the suspension wouldn't reach. I've never read anywhere here about that being a problem. The lift was a 3/2...
Now I'm looking at trying to order a Daystar 2.5/1.5 lift online and try to find somewhere else to have it installed.
I emailed readylift to ask about this myself, and I'm not looking for another option. If I have to do the install on a new Daystar, is there much to it?
I hear they have a new "Easy Install" but couldn't find a thread with a how-to on it. I also have almost no tools, and no jack to lift my vehicle except for what it came with.
So far I can't find any shops around that will install a level kit, or change the suspension for me. Toyota won't touch it, nor will the other shops here that normally do lift kits on vehicles.
Someone tell me I'm not completely **** out of luck!:ybrick:
It's pretty typical for shops to try to avoid working on the xreas suspension. There shouldn't be any issues, but most shops don't want the liability. As long as it's a 4runner kit, it should fit. Where are you located? Possibly a member near you could help out.
I'm going to guess Newfoundland Canada.
Do you have a buddy or family member that has a proper lift and some basic tools? you only need a socket set, some pry bars, and a hammer I think.
If you dont have much experience though you definitely should have a friend that is familiar with working on cars, it is a 2 man job, it takes some teamwork to get the coilover in and out, unless you disconnect the lower control arm maybe.
The spacer kits that are meant for the 4Runner should all fit fine, it takes a bit of problem solving to figure out how to get the coilover out without disconnecting xreas but it is definitely doable.
The old man and I got it done no problem.
That shop just saw the xreas system and didnt want to mess with it because it would cost them a good amount of money if they accidentally disconnected it.
I'm in north carolina setup with tools and anything you need probably slim chances your close by but holler if i can help. They probably couldnt figure out how to get the spacers in without disconnecting the xreas hydraulic lines...noobs..lol
Supposedly, the new Easy Install daystar kit does not required you to compress the spring.
Related question: if installing a Day Star lift, how much harder is it to throw some FJ springs on? Is it as simple as slipping the stock off and slipping the FJ's on?
Thanks for all the feedback guys, it's looking like it may have to be done at home..
thanks for the offer but yeah I'm in central newfoundland, if there are any members near there let me know
Damn XREAS system!
You could remove the XREAS and install some good shocks and a real lift.
What is the age/mileage on the XREAS? It may be time to replace it anyway.
well it's an '05 and got about 144,000 km... so if the suspension won't last much longer then maybe I should consider getting that done? I seen the toytec ultimate is about $1200 online, but how much is there to the installation of that?
So I emailed readylift and they said you can install this kit, and gave me the number to their support if I or the garage have any questions. Went back to the shop and told them and they still won't touch it. I guess they are afraid of it, now to continue my search...
youngrk
