Lift questions
wifestoy
If I put 2 inch coil spacers on the rear will I need new shocks or will the stock ones work. Thanks for the knowledge everyone this forum is great.
The stockers will work, but you'll lose "droop" or downward suspension travel. I've noticed this with even just 3/4" of lift (FJ coils) in the rear while off-roading. Even dropping a front tire off of a small obstacle tends to lift the opposite rear tire off the ground. I will say, however, that a lot of people have used the Daystar 2.5/1.5 and Cornfed 3/2 spacer lifts on stock suspension without problem and have enjoyed them for years. You'll be fine unless you're trying to improve your flex.
ghengiskhan
