lift setup for now and for later......
hdoggie24
Member
well right now i have new 31x10.5 15's on my 97 2wd runner. with this setup im leaning towards the ome 881/906. haven't bought anything yet for the lift. my question is for the in a couple years from now. i want to keep my 15s cause i like them but when my old tires get a bit old i wanted to possibly get 33x10.5 for my 15s. so would the lift im planning on putting on 881/906 work with the 33s i will eventually get. seems like 31s are a tad too small from what people say so i will go bigger when they get worn down. anybody have any ideas for what i should do now and down the road. i really don't want to have to buy new coils later when i put 33's on my rims. so would 881/906 work for both tire size or should i use a different setup intially. i did some research but still wanted to ask this question to see what people would say. thanks.
33's are a push with that vehicle anyways without a 1" body lift or some trimming.
So I think the springs will work. They don't make a taller spring for the rig anyways, so its not like you can just pick a different coil to get a higher lift. With the 881's, you could not run the top plate spacer now, and then install that when you change tires. That will yield you almost another full inch of lift.
TheWhite4Runner11
