Lifted, Rear shock help
Desert36
So the rear springs are ome891, one side is sagging and I could see where fluid was leaking from that shock(32334). I need to change them and can't find that thread I saw a while back about measured travel differences and part#'s.
I plan on adding a 1" spring spacer on the rear, but need to get the correct shocks. So if anybody has good advice, point me in the right direction.
Primary use is all off road, aired down & locked up.
On a side note while inspecting under there I noticed the brake cables may be limiting some travel so I will be making those adjustments as well, any tips appreciated.
Thanks :thumb3:
patnewton
