Light bar switches.
Paragon1
Member
Okay, I've looked all over the place using search and even the Google machine on the Interweb. Someone here installed a set of rocker switches that replace the cubby hole below the AC and accessory USB ports. Can someone point me to it? Cheers.
I think I saw the ones you are referring to, they were blue LED switches and they were posted just a couple of days ago!
Searching....
I used a 6-switch blank from OTRATTW. They're local to me so they fired up the laser machine to etch me the blanks. They keep most of the common switches in stock.
Are these a direct fit for the cuby hole or did you have to do some dremel work to get it to fit?
I went with OTRATTW rockers with amber lighting since I have a 2013. uploadfromtaptalk1461072122110.jpg
Sent from my SAMSUNG-SGH-I337 using Tapatalk
