Light bulbs.
side markers
a 194 bulb will work for a side marker but not sure if that is the recommended bulb.
I believe a 168 bulb will work as well. Pull out your burned out one and take it to the store-they will recognize it. Also they will have a book or computerized kiosk to tell you the correct bulb to buy.
Go OU Bobcats!
The corner lights are for sure 194.
However, the interior light is a whole different ball game.
I have a 2000 Limited and most of my interior light bulbs are 74 such as the glove compartment and shifter, cigarette lighter and so on. In terms of the climate control stuff, I have Neo-Wedges but I was not sure which size so I ordered two of each from this website: www.autolumination.com
For the corner lights go with a 921, it's a bigger bulb than the 168 but it uses the same base, so it'll work!
Go OU Bobcats!
194 and 168 are the same exact bulbs. 158, 161, 168, 906, 912, 921, 922, 2825, and 2821 are also the same as the 194 and 168.
so many interchangable part #s
thanks FoSheezy
figured you would know the corner bulb numbers!
okay mine just burned out the right side side marker light and 2825 was the bulb listed for replacement. I never knew the 168 and the 194 were the same bulb, I thought they just looked identical-nice to know now.
No problem at all man, yeah it's odd that there are so many different number combinations for just one bulb.
