Light Duty Portable Compressors
mtomaro
I've been shopping around for a light duty portable compressor for airing back up after a day on the trails. I want something that's tough enough to be mounted in the engine bay for easy storage. The higher the duty cycle the better but I'm ok with the 33% mark as taking 15-20 minutes to fill up my tires really isn't a big deal to me. I often use this time to reorganize everything in my rig. Based on my expected use I also want to keep in under the $100 mark.
I got a Viair 88P and while it performed perfectly for what I wanted, I didn't like the fact that the air hose was permanently attached which will make storage in the engine bay a nightmare. I was really hoping to just keep a air hose detached in with the rest of my gear in the trunk.
I'm now looking at the Smittybilt 2780 - similar performance, similar price point, detachable hose. Now I need to decide if I want to modify the viair hose with a QD at the compressor, go with the Smittybilt, or go elsewhere. I'm curious to hear other thoughts and experiences.
Should be pretty easy to put an air disconnect on the Viair. I bet the barb fitting on the stock hose is NPT, the one on my 90p is.
I like Viair products and have used the portable units and have mounted a 480 under the hood of my T4R. It is 100% duty cycle at 100 PSI.
IMAG0115_zpsdyudsfvc.jpg~original
The hose on the 88p is permanently attached. It goes directly inside the compressor cover with no fitting. I haven't taken it apart yet to see how it attaches under the casing but i would probably just cut the hose a few inches off the body and crimp on a QD.
Great compressor but its really overkill for my planned use at this point.
Smittybilt air compressor on Amazon for $80. Works great for my 3T4R.
spend a bit more and get the bigger one.
http://www.amazon.com/Smittybilt-2781-5-65-Universal-Compressor/dp/B004K25GMG
its a much better compressor than the 88p
it fills my 35's up very quickly.
I use the classic and reliable mv-50. It's mounted in my engine bay and will fill my 33's from 18-35psi in about 2 minutes each. As long as it's not 100 degrees outside I've filled up vehicles all with 33's without thermal shutdown. If it's really hot outside I may get 2 vehicles aired up before thermal shutdown. I've been using it for about 2 years with no issues.
