light quit working on 115V switch
wadeanderson
I know it is probably coincidence but the light worked fine all along and after I picked up from the detail shop it was no longer working. There is still power at the plug when the switch is pushed in but the light no longer comes on, is it possible they could have hit a wire or done something? I know it is unlikely but thought I'd ask anyway.
So that would lead to my next question, how do I fix it?
can I replace the bulb inside the switch, if so how do I do that? I tried to search the forums but did not find anything.
Another thing that started happening since being in the detail shop is there is an intermittent cutting out of the power when we have our phone charge adapter plugged in that has two USB plug ins on it and we are charging both phones at the same time. Both phones stop charging then start, then stop, then start, etc... When one phone is plugged in there is no problem. It is as if there is too great of a load and it keeps cutting out. Anyone know what might be going on?
Thanks!
Wade
Pop the switch out and you can easily swap out bulbs. I had to on mine. You also see if the bulb just twisted if it worked before, might just be that.
