Lighting info from the MAN
KYBubblehead
I'd written to Daniel Sterns about upgrades for the lights on our 4th gen 4Runners; here, with his permission, is his reply:
Daniel Stern Lighting <[email protected]>
Jan 5
to me
Hi, John. Thanks for writing:
sent for some DupliColor Metalcast Yellow to do the
fog light lenses (based on your writings) on my ’04
4Runner, but my question is: what bulbs should I put in
“Big White†to maximize light output? I believe the low
beams require a 9006 bulb… Is there a bulb I can buy that
will actually give me more light on the road?
Before we talk about bulbs, Take careful note: when "plastic" (polycarbonate) headlamp lenses are yellowed or clouded or fogged, it's really time to replace the lamps with new original-equipment ones. There are various polishing/restoration kits on the market, none of which will do anything but postpone your need to install new headlamps because what you are doing in "polishing" the headlamps is scrubbing off the anti-UV/anti-scratch hardcoat that was applied and crosslink-cured under cleanroom conditions when the lamps were manufactured. With this coating gone, the degradation will come back faster and worse than before.
Many of the kits contain what they claim to be a coating, lotion, wax, protectant, sunscreen or other such goop; none of these does much of anything to slow or stop the degradation. There is no field-applicable coating that can duplicate the factory coating's performance (which itself is inadequate to the task, as a walk through any parking lot shows -- the regulations are too lax), though if you need to buy some time, you might try the technique at DIY: Restoring Headlights with New UV coating - MY350Z.COM Forums .
A lamp that is not in as-new condition is not worth using. Optical degradation of the reflector is grossly advanced well before you can see it with the naked eye; by the time it's progressed far enough to be described as "just a little imperfect" the lamp is dead. Remember, even the most costly, beautiful show chrome is only 67% reflective, not nearly enough for optical purposes. An as-new headlamp reflector is over 99% reflective. The takeaway message here is that even if the reflector looks OK, its optical efficiency is way down if it's got some years on it.
Replacement headlamps need to be original-equipment items (automaker's own brand, genuine Toyota parts https://www.amazon.com/dp/B005VO07AI/?tag=2402507-20 and https://www.amazon.com/dp/B005VNZFYC/?tag=2402507-20 )
because all(!) of the aftermarket off-brand items -- TYC, Depo, DJAuto, Eagle Eye, Helix, etc -- are garbage, despite spurious claims of "OEM quality", "SAE/DOT approved", "CAPA certified", "NSF certified", etc. This is worth a careful look at your present headlamps, too, in case the vehicle received aftermarket replacement headlamps sometime in the past.
With genuine headlamps in perfect condition, use http://www.amazon.com/dp/B00BQWQLQI/?tag=2402507-20 for the low beams.
If you want to upgrade the high beams, get https://www.amazon.com/dp/B000C9QPKS/?tag=2402507-20 . That is a genuine 9011 HIR1 bulb. They are not some tinted or overwattage version of 9005, but share the identical filament geometry and base architecture as well as the same power consumption.
Here's the comparison:
stock: 9005, 12.8V, 65W, 1700 lumens, 320 hours
new: 9011, 12.8V, 65W, 2530 lumens, 320 hours
The 9011 bulbs have a double-wide top ear on the plastic bulb base, this is
to comply with the law requiring different bulbs to have different bases.
The extra-wide plastic top ear is easily trimmed or filed to make the bulb
fit your headlamp's bulb receptacle. Once that's done, they go directly
into the headlamp, and the existing sockets snap on. Please see
HIR bulb base modification for details. Disregard Amazon's warning that the bulbs won't fit your car.
You will need to see to it that the lamps are aimed carefully and correctly per the "VOR" instructions at Daniel Stern Lighting Consultancy and Supply .
Cheers DS
Very much true. You can spend an hour wet sanding and polishing a headlamp and it will look brand new....for a week. One fix I have used which has worked very well for me is to wet sand, polish, then cover with a protective film (i used xpel clear bra). My headlights still look new almost 2 years later.
I'm already using the 9011 upgrade...FAR superior lighting output (~80) brighter) using the same wires, draws, etc...all my vehicles have the upgrade to think about it...good information and well worth the upgrade! I just traced the OEM bulbs into the some cardboard I stuck the bulb in and copied it to the new 9011 bulbs using a pair of tow nail trimmers...easy as can be and superior light output!
johnnya
