Well i just took a slight plunge and ordered a set of the Xenon Depot extreme/philips H11 kits after a long time of thinking about it. The order went smooth and i expect the install will as well.
Ill try to do the install at night so i can take some useful before and after pictures.
Now im wondering if i should upgrade (not HID) the high beams to a better bulb. Are there any good 9005 replacements that i should look into? I doubt ill be using the much but it may be a good time to change them.
How about the fogs? I thought about changing those to 3000k HID but am going to hold off until i see these. Are there any good non HID bulbs for yellow or white light. Yellow would probably be more useful but im open to suggestions.
Let me know what yall think and before i get them let me know if there are any install pictures any of you may want.
Does anyone have any good install or alignment tips? I thought i remembered someone changing something on the lense. I think ill try to use a good strong velcro along with a zip tie when i can instead of screws. That should allow the kit to be removed if need be.
For XenonDepot: I didnt screw up ordering the phillips bulbs did I? I assume ill be able to get replacements down the road or should i buy a spare set if these work out?
