Like the Look?
JohnsD90
This is what i am going to be doing over the next few weeks. Do you like it?
It will be clear corners and turns, 01 Tails (LINY's), and Ditching the running boards. Greenmonster helped mod the pic.
99 Talls with bilsteins, getting um from a friend, maybe making sliders in may. And LED lights in the dash.
I like the look so far :thumb3:
'99 talls are still Toyota springs which means that they will sag. If you have '99 talls on the rear and leave the fronts as is then it will probably sit close to level when the rear starts sagging.
Looks good, as someone said enjoy your amber corners, not to mention the clears are illegal in some states...may want to drop an amber bulb in there to be sure. Hell I run amber bulbs in the stock corners and they look sick, at least try that before you switch over
